Rule won't set more than one scheduler Eco Mode
Running version 2.3.4.115
I've got a rule that is intended to set all my thermostat schedulers to Eco Mode. I can see in the log that the rule run but not all schedulers will turn Eco Mode ON/OFF. I can reproduce the same behavior just by pressing run actions in the rule.
Schedulers before:
Schedulers before
The rule actions, select by App Name (one action for each scheduler):
I click on Run Actions and after, only the last scheduler is activated:
Scheduler After
Let's try something else! This time select by thermostat and select all (all scheduler at once):
Run Action and then, still only one scheduler activated, but this time it is the first one:
SameButFirst
Anybody has an idea what's wrong?
I can confirm this behavior. Will get it sorted out.
Bug found, and will be fixed in the next release.
Thanks for the fast response! :+1:t2:
I confirm, problem solved with 2.3.4.117.
Hi @bravenel , I found out there is still a bug when setting more than one scheduler, when using Select by thermostat.
Here I create a rule with only one action to set all my schedulers to Eco.
I selected all available thermostats
The result is only one scheduler gets activated
Only one set
To workaround, it still works to create multiple actions, one by scheduler, with Select by App Name
Thanks for you help, I wish you happy holydays.
EDIT: I'm currently at version 2.3.4.123
Yeah, that never did get fixed.
