Rule triggered even if condition condition false
I have these conditional triggers that run even when the condition is false:
The action is executed without the trigger:
If I make the condition true, trigger is logged:
Could you add info logging to the « Angelo » device so that we may also see it’s status (for confirmation)?
What build is your hub on?
Platform Version
2.4.0.151
C7
Rule:
Tested switching presence, this time the trigger doesn't show up in rule's log.
I will look into this. Is it only those two Conditional Triggers that are failing out of all of them?
I’ve been able to reproduce when both « departs » and « arrive » are included as triggers. When « arrives » is the only trigger, the rule behaves as expected:
With only one trigger:
With both triggers:
@Sekenenz I am not able to reproduce this on 2.4.1, now in beta. You might want to join beta to check that out, or wait for 2.4.1 public release.
I'll wait next release
