Rule showing false but is true?
@bravenel i have a rule that is automating my window blinds in my bathroom. Today I noticed the blind was down and did not open at sunrise per my rule.
Here is the full rule:
Here is the log from this morning.
Trying to understand why it skipped running. Everything was working up until this morning.
Is that all one rule? That's a lot of moving parts, and none of us know which button press is associated with open vs close.
Among all of those if-elses, which part exactly didn't work as intended?
Push 6 is open and push 5 is close. The blind didn’t open at sunrise and it hasn’t opened since motion stops in the same room during the day. Push 5 is being skipped. In Lutron the blind shows closed which it is.
I see, the Else is all true but reporting false.... Odd
Yes that’s what is perplexing me.
Ah, gotcha - thanks!
That said, it is right on the sunrise time, maybe that has something to do with it?
When I walk into the room and then motion goes inactive and it runs the rule again, it is skipping push 5 and I believe it’s due to the Else showing false when it should be true. I just don’t know why the else is false.
I see it now... Was something recently removed from that statement? You have two ANDs back-to-back as if there was once something between them? Or perhaps an extra AND was somehow inserted recently?
I think that double AND is what's screwing it up.
Oh good catch. I did t even see that. Let me see if I can fix that.
That was it! Thanks for a double set of eyes!!
