Looking for help. I have a couple hallways that have a lutron dimmer on one end and the pico remote at the other. I was a rule that Everytime the light goes on it will fade back to 0 after a minute or 2. Seems easy and it works when I set the trigger using the dimmer, however it doesn't work when the pico is used to turn on the light.
Can you share a screenshot of your rule?
Figured it out.
Good talk.
