With the latest version we now have some access to the Weather Underground API. Are there any examples of using this within Rule Machine?
Rule Machine doesn’t have any hooks into weather. Perhaps it should?
Got it. So in order to use the outside weather to help drive when my house fan, etc are on or off, I need to code a new app using the API. It would be really nice if you could put in at least a current temp for comparison sake.
There is a driver called "WeatherUnderground" but I haven't seen any documentation on how to use it. Once setup Rule Machine could use an attribute from that device correct? Could examples be posted on how to setup a working WeatherUnderground virtual device?
Rule Machine allows you to control any device through Custom Commands. But it doesn’t allow any sensor as a condition, only the coded ones. Presumably the use would be as a “sensor” for a condition in RM.
Yes this would allow me to emulate my ST stuff. Lights turn on at certain levels based on lux, fans turn on/off at certain temps/humidities. Alerts are sent based on temp/humidity. Etc.
I use the ST weather tile for similar thing. The weather underground driver doesn't seem to work with the API access right now.
Just bumping this as I would like to use 'solarradiation' as a lux reading.
Are there any plans to enable this?
I can see the readings using the 'weatherndergroundcustom' DH but cannot get the info to write into a variable in webCoRE.
Just bumping this again in case someone has found a solution to this.
I've added a weather device using the custom ApiXU Weather Driver.
I'd like to include some of the states from this device as condition(s) to control other devices and/or provide notifications.
For instance, I'd like to receive a notification if I've left any windows open and it's raining. More importantly I have a gutter warming system to prevent ice dams. I'd like to turn it on/off automatically if it's snowing and within a certain temperature range. The precipitation information (using condition code/description) would be useful to me.
