Hello everyone! I LOVE Hubitat! it is the most stable system I ever installed! I struggle with the rule. I want to: If variable ALARM is on, AND my office door is closed AND motion office is active, then obviously someone entered by the window. Then Notify my cell phone. Both door and motion senseors are working but not the rule. What am I missing? Thank you.
You have created conditions, but you’re not actually using them in the rule. Notice that next to each condition it says “unused.”
As @ritchierich said, you need to create a trigger for the rule. And then use the conditions to restrict when the rule triggers.
Thank you guys. I think I understand. Let me try.
Your conditions are still unused. Right now you have the trigger set to active motion and it immediately calls the actions to notify you.
As mentioned above click the required expressions slider above the trigger. Required expression are a set of conditions that must be TRUE in order for the actions to be called. Enter your conditions there making sure you set an AND between the conditions similar to the screenshot I provided above.
You don’t need the motion active condition at all because that is your trigger for this rule. You. A delete that condition in Manage Conditions.
This.
You have made specific conditions available for this rule to use.
But the rule is not actually using them.
The documentation for Rule Machine is a helpful reference for understanding Conditions, Triggers, Actions and basic rule building.
