I am migrating my SmartThings devices over to Hubitat Elevation and writing all new rules. I am a software/hardware engineer so, after a few hours, I am having little trouble with the Apps.
I have a rule setup and tested that if a Lutron dimmer exceeds 80% or is turned on to 100%, a Z-Wave switch is turned on.
Then if the dimmer goes under 80% or is turned off, the Z-Wave switch is turned off.
This worked and worked very well yesterday. I turned off descriptive text logging on the Lutron Caseta dimmer and both rules stopped working. I turned back the descriptive text logging and both rules now work flawlessly.
Is this a bug or intentional? I would think that this is a bug.
Caseta wall dimmer. What other home Lutron dimming device is there? Well, there is the version that has a neutral wire but this is a standard one like you buy at Home Depot or Lowes. And, yes, I have a Caseta Pro hub. I wrote the first driver piece for HomeAssistant years ago.
