When creating the setCode action in Rule Machine I am setting up the 2nd parameter as a string and entering the %TempCode% global variable I created. It is showing TempCode(null). Did I miss something or stumble across a bug? @bravenel
Did you create a connector for that GV?
Yes, the interesting part is that it recognizes the variable value in the IF statement, but does not recognize it in the setCode section in Rule Machine. (Can be seen in the second picture in my first post.)
The variable name should not be inside %. That's only for fields that expect a number or something.
Thanks, I will give that a try. Appreciate your assistance.
That was it, really appreciate you taking the time to set me straight.
