Model C7, firmware version 2.3.7.146
When creating a rule, error shows:
Error 404. App type with namespace: hubitat and name: Rule-5.1 has parent type that does not match current app
I have tried removing the rule Machine app, soft restart. If I roll back to a previous version (2.2.2.126) I am able to create a rule but do not have access to the kasa integration in that version.
Can anybody help me with this problem?
Try hitting this endpoint -- just navigate to it in your web browser -- replacing hubitat.local
with your IP address, ideally (or your actual mDNS name if that's not it and you want to try for some reason) to see if it helps:
http://hubitat.local/hub/advanced/reloadAppAndDriverDefinitions
Wow that fixed it!! Thank you very much!
This topic was automatically closed 24 hours after the last reply. New replies are no longer allowed.
