Clearly, a great deal of work went into 2.4.0. Thanks.
I understand the issues regarding upgrading/downgrading between major platform versions.
However, Iāve got a question regarding Rule export/import across major platform revisions in view of the following points in the 2.4.0 release notes:
- Added IF/THEN/ELSE logic to Visual Rule Builder.
- Rule 5.1: Added new table based UI for Triggers and Conditions, allowing one click to create new, edit or delete.
- Rule 5.1: Rule Functions available
If Rule export has been used to archive a group of rules, can that export file later be used for import into a later major platform revision?
Likewise, if a Rule export has been used to archive a group of rules, can that export file later be used for import into an earlier major platform revision, providing that a feature not present in the earlier platform revision (e.g., Rule Functions) is not used in the exported/imported rules?
