You won't actually use set color. One menu up there is another type of control command called set color temperature. Use that instead of setting color.
I mean... You can if you want. But if you are trying to set "Daylight" that isn't a color. It's a color temperature. If you want to do a color using HSV you can choose a yellow through blue hue and drop the saturation to near zero. But if you don't want to go look up or test out hue values it's just easier to pick a color temperature...
I had no idea that "Color value" was a Hue value ranging from 0-360 and that Temperature was measured in Kelvins (K) with values ranging from 1000 to 10000.
So, I should mention one little hitch. Depending on your bulb and driver your hue values actually might only go from 0 to 100 instead of 0 to 360. This is super annoying to me. SmartThings, the hub that a lot of Hubitat is modeled on, used 0 to 100 (incorrectly in my opinion) and HE adopted that because of the driver structure.
So, apps like Groups and Scenes actually enforces a 0 to 100 value for hue. You better hope the driver you have has a 0 to 100 setHue function. Almost all do.
So, take your 0 to 360 graphic and scale 0 to 360 across just 0 to 100 and you'll have the values you probably need to use.
