I have a FC200 which has the ability to set the color of its LED lights. When I go to create a rule in RM5, I do not see the Custom Command or option to set the LED color (in RM4 it was setLEDstatus). Does setLEDstatus exist in RM5?
Does the driver have a setLEDstatus command? If so, it should show up under Custom Command for that device.
It does under RM4 but I don't see the Custom Command in the drop down with RM5
I don't know what FC200 is, but pick any attribute that it supports from that pull down, then select the device itself. That should present all of its commands.
Oh Duh! I was clicking on Create Conditions instead of Select Action (wiping egg from my face)
