Was having an issue with only some time triggers actually firing. Edited one of the non-firing triggers to slightly change the time. Now attempts to edit triggers generate an exception:
java.lang.ClassCastException: java.lang.Integer cannot be cast to java.lang.String on line 647 (selectTriggers)
Doing it again just displays a blank triggers list with no editing options, and a slightly different exception:
java.lang.ClassCastException: null (selectTriggers)
Rule Machine 4 : Multiple Time Triggers not working has more info
I made a copy of the "bad" database and restored to yesterday's backup. This allowed me to get back into the triggers list and delete all of the triggers. I replaced them with an "every 5 minutes" trigger.
At this point, the rule is not firing at all, despite the new trigger! I checked the status page for the rule and it shows 3 scheduled jobs, all for some of the now-deleted triggers.
I tried pausing/unpausing the rule, this does not seem to have reset anything - still 3 scheduled jobs. I also rebooted the hubitat, no apparent change.
