Ok I also did it.
OK, now look at the App Status page for event subscriptions and see if there is one for that device.
One more thing.. There is no "descriptionText Logging" in my sensor preferences. I turned it on for my phone device. I don't know if it's that what you wanted me to do.
My sensor preferences look like that:
I've lost track of what this rule looks like. Please post a screenshot of the main page.
It checks if all my sensors are present and should send me a notification to my phone if the state changes.
I use these drivers for my sensors:
NOTE: Although Xiaomi / Aqara devices are used by many users with great success, Xiaomi / Aqara Zigbee devices are NOT officially supported on HE. Why new drivers? Xiaomi / Aqara drivers was something I wanted to write my own version of. Since @veeceeoh isn't here to support his I thought I'd release mine. I have published drivers for most types of Zigbee devices from Xiaomi / Aqara, if any are missing it's probably because I don't have the specific device. With this said, a big thank you goes…
And would like to use presence functionality to check if all sensors are good.
Allow me to suggest that you collapse all of those triggers into a single trigger with multiple devices selected. And show the Event Subscription section of the App Status page. I'm not sure why the rule is not triggering, but can dig into it.
I cant collapse them. It's custom attribute and I cant tick more than one device. See the screenshot:
Event subscription:
OK, thanks. I need to spend some time investigating what is going on. I will get back to you...
Try using 'Presence' instead of custom attribute in the trigger. Then you can select all devices that reports presence
I did it. Thanks.
Now I can see some events in my app status. But I still don't get notification to my phone.
Need to see the logs of the rule with Events, Triggers and Actions all on.
I did find a bug as to the original way you were doing this with Custom Attribute, and a fix for that will be in the next release.
Ok thank you. I am waiting
Hey
Everything works after update. Now I get the notifications. But there is one more problem - sometimes I get the same message twice or even three times in the same moment.
Need to see the logs to show what is going on.
Your device appears to be sending multiple events. Look at the device Events, available on the device page.
It's the driver that does it. What is this driver?
It is a driver from that thread:
