Hey
I have a problem with RM4.1.
Screens below
When any of my devices reports 'not present' status I should get a message to my phone.
But it doesn't work. Nothing happens when the state changes to 'not present'.
Help please
Try hitting "Done" or "Update Rule" if you haven't already to see if that helps. If not, turn on logging for triggers and actions (at least) and see if you get any clues there.
Yes I tried using "Done" and "Update Rule".
I also turned on logging but there are no logs for this app in "Logs" section.. Strange..
Show the App Status page for the rule (gear icon). You're looking for Event Subscriptions.
try redoing the notify .. delete re-add looks like there is a control character or carriage return in there.. as they all should be on one line.
Turn on logging for Events, Triggers and Actions. Show what happens... Use screenshot.
I tried. Nothing changed.
I added one more sensor called "Czujnik rezerwowy" to the list and forced change of "presence" status to true but events table is still empty. Screenshots of status of the rule and events table below.
I don't know why "allVars" has this strange values inside. It looks like my another rule "Lista zdarzen" which monitors when my doors or windows were open/closed.
Hey
Could you please help?
Still need to see the logs that show a failure.
Where to find these logs?
Ok I also did it.
OK, now look at the App Status page for event subscriptions and see if there is one for that device.
I've lost track of what this rule looks like. Please post a screenshot of the main page.
It checks if all my sensors are present and should send me a notification to my phone if the state changes.
I use these drivers for my sensors:
NOTE: Although Xiaomi / Aqara devices are used by many users with great success, Xiaomi / Aqara Zigbee devices are NOT officially supported on HE. Why new drivers? Xiaomi / Aqara drivers was something I wanted to write my own version of. Since @veeceeoh isn't here to support his I thought I'd release mine. I have published drivers for most types of Zigbee devices from Xiaomi / Aqara, if any are missing it's probably because I don't have the specific device. With this said, a big thank you goes…
And would like to use presence functionality to check if all sensors are good.
Allow me to suggest that you collapse all of those triggers into a single trigger with multiple devices selected. And show the Event Subscription section of the App Status page. I'm not sure why the rule is not triggering, but can dig into it.
