Rule - Help
So I want to create a rule that will fade my lights on, but if I press the button on my pico remote to turn off the fading up rule over 30 minutes, it will cancel the active rule.
Anyway of doing this?
I think I figured it out.
I made another rule and said if pico button 5 is pressed it will cancel this rule.
I assume that will do it?
Correct. You use rules like building blocks. One supports the other.
Thanks!
