Can you show me a screen shot of the Device Events for that device?
OK, can you post a screenshot of the Motion Lighting app detail page for Office Lights On. It might take two.
Ah, I see the problem. That device is not reporting "physical" events, and the app is looking for "physical". I will investigate why that is (it has to do with the driver).
Would you check one more thing: Please open the device page for Office Lights and hit refresh. Then open Device Events, and take a screenshot of it, post it.
I also added the custom driver that I usually use for these dimmers if this can be modified also.
* Copyright 2017 Jason Xia
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Leviton Decora Z-Wave Plus Dimmer", namespace: "jasonxh", author: "Jason Xia", ocfDeviceType: "oic.d.light") {
capability "Actuator"
capability "Configuration"
//capability "Health Check"
capability "Indicator"
capability "Light"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Switch"
capability "Switch Level"
attribute "loadType", "enum", ["incandescent", "led", "cfl"]
attribute "presetLevel", "number"
attribute "minLevel", "number"
attribute "maxLevel", "number"
attribute "fadeOnTime", "number"
attribute "fadeOffTime", "number"
attribute "levelIndicatorTimeout", "number"
command "low"
command "medium"
command "high"
command "levelUp"
command "levelDown"
fingerprint mfr:"001D", prod:"3201", model:"0001", deviceJoinName: "Leviton Decora Z-Wave Plus 600W Dimmer"
fingerprint mfr:"001D", prod:"3301", model:"0001", deviceJoinName: "Leviton Decora Z-Wave Plus 1000W Dimmer"
preferences {
input name: "levelIncrement", type: "number", title: "In-App Level Increment",
description: "1 - 100 (default $defaultLevelIncrement)", range: "1..100", defaultValue: defaultLevelIncrement,
displayDuringSetup: false, required: false
input type: "paragraph", element: "paragraph", title: "Device Preferences",
description: "The following preferences are configuring the device behaviors. " +
"All of them are optional. Leave a preference empty to skip configuring it."
input name: "loadType", type: "enum", title: "Load type",
options: ["Incandescent (default)", "LED", "CFL"],
input name: "indicatorStatus", type: "enum", title: "Indicator LED is lit",
options: ["When switch is off (default)", "When switch is on", "Never"],
input name: "presetLevel", type: "number", title: "Light turns on to level",
description: "0 = last dim level (default)\n1 - 100 = fixed level", range: "0..100",
input name: "minLevel", type: "number", title: "Minimum light level",
description: "0 to 100 (default 10)", range: "0..100",
input name: "maxLevel", type: "number", title: "Maximum light level",
description: "0 to 100 (default 100)", range: "0..100",
input name: "fadeOnTime", type: "number", title: "Fade-on time",
description: "0 = instant on\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes", range: "0..253",
input name: "fadeOffTime", type: "number", title: "Fade-off time",
description: "0 = instant off\n1 - 127 = 1 - 127 seconds (default 2)\n128 - 253 = 1 - 126 minutes", range: "0..253",
input name: "levelIndicatorTimeout", type: "number", title: "Dim level indicator timeout",
description: "0 = dim level indicator off\n1 - 254 = timeout in seconds (default 3)\n255 = dim level indicator always on", range: "0..255",
def installed() {
log.debug "installed..."
initialize()
response(refresh())
def updated() {
if (state.lastUpdatedAt != null && state.lastUpdatedAt >= now() - 1000) {
log.debug "ignoring double updated"
return
log.debug "updated..."
state.lastUpdatedAt = now()
initialize()
response(configure())
def configure() {
def commands = []
if (loadType != null) {
commands.addAll(setLoadType(loadType))
if (indicatorStatus != null) {
commands.addAll(setIndicatorStatus(indicatorStatus))
if (presetLevel != null) {
commands.addAll(setPresetLevel(presetLevel as short))
if (minLevel != null) {
commands.addAll(setMinLevel(minLevel as short))
if (maxLevel != null) {
commands.addAll(setMaxLevel(maxLevel as short))
if (fadeOnTime != null) {
commands.addAll(setFadeOnTime(fadeOnTime as short))
if (fadeOffTime != null) {
commands.addAll(setFadeOffTime(fadeOffTime as short))
if (levelIndicatorTimeout != null) {
commands.addAll(setLevelIndicatorTimeout(levelIndicatorTimeout as short))
log.debug "Configuring with commands $commands"
commands
def result = null
def cmd = zwave.parse(description, [0x20: 1, 0x25:1, 0x26: 1, 0x70: 1, 0x72: 2])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "Parsed $cmd to $result"
} else {
log.debug "Non-parsed event: $description"
result
def on() {
def fadeOnTime = device.currentValue("fadeOnTime")
def presetLevel = device.currentValue("presetLevel")
short duration = fadeOnTime == null ? 255 : fadeOnTime
short level = presetLevel == null || presetLevel == 0 ? 0xFF : toZwaveLevel(presetLevel as short)
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: level, dimmingDuration: duration).format(),
zwave.switchMultilevelV1.switchMultilevelGet().format()
], durationToSeconds(duration) * 1000 + commandDelayMs)
def off() {
def fadeOffTime = device.currentValue("fadeOffTime")
short duration = fadeOffTime == null ? 255 : fadeOffTime
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: 0x00, dimmingDuration: duration).format(),
def setLevel(value, durationSeconds = null) {
log.debug "setLevel >> value: $value, durationSeconds: $durationSeconds"
short level = toDisplayLevel(value as short)
short dimmingDuration = durationSeconds == null ? 255 : secondsToDuration(durationSeconds as int)
sendEvent(name: "level", value: level, unit: "%")
sendEvent(name: "switch", value: level > 0 ? "on" : "off")
delayBetween([
zwave.switchMultilevelV2.switchMultilevelSet(value: toZwaveLevel(level), dimmingDuration: dimmingDuration).format(),
], durationToSeconds(dimmingDuration) * 1000 + commandDelayMs)
def poll() {
delayBetween(statusCommands, commandDelayMs)
def ping() {
poll()
def refresh() {
def commands = statusCommands
if (getDataValue("MSR") == null) {
commands << zwave.manufacturerSpecificV1.manufacturerSpecificGet().format()
for (i in 1..8) {
commands << zwave.configurationV1.configurationGet(parameterNumber: i).format()
log.debug "Refreshing with commands $commands"
delayBetween(commands, commandDelayMs)
def indicatorNever() {
sendEvent(name: "indicatorStatus", value: "never")
configurationCommand(7, 0)
def indicatorWhenOff() {
sendEvent(name: "indicatorStatus", value: "when off")
configurationCommand(7, 255)
def indicatorWhenOn() {
sendEvent(name: "indicatorStatus", value: "when on")
configurationCommand(7, 254)
def low() {
setLevel(10)
def medium() {
setLevel(50)
def high() {
setLevel(100)
def levelUp() {
setLevel(device.currentValue("level") + (levelIncrement ?: defaultLevelIncrement))
def levelDown() {
setLevel(device.currentValue("level") - (levelIncrement ?: defaultLevelIncrement))
private static int getCommandDelayMs() { 1000 }
private static int getDefaultLevelIncrement() { 10 }
private initialize() {
// Device-Watch simply pings if no device events received for 32min(checkInterval)
//sendEvent(name: "checkInterval", value: 2 * 15 * 60 + 2 * 60, displayed: false, data: [protocol: "zwave", hubHardwareId: device.hub.hardwareID])
private zwaveEvent(hubitat.zwave.commands.basicv1.BasicReport cmd) {
dimmerEvent(cmd.value)
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelReport cmd) {
private zwaveEvent(hubitat.zwave.commands.switchmultilevelv1.SwitchMultilevelStopLevelChange cmd) {
response(zwave.switchMultilevelV1.switchMultilevelGet().format())
private zwaveEvent(hubitat.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd) {
if (cmd.value == 0) {
switchEvent(false)
} else if (cmd.value == 255) {
switchEvent(true)
} else {
log.debug "Bad switch value $cmd.value"
private zwaveEvent(hubitat.zwave.commands.configurationv1.ConfigurationReport cmd) {
def result = null
switch (cmd.parameterNumber) {
case 1:
result = createEvent(name: "fadeOnTime", value: cmd.configurationValue[0])
break
case 2:
result = createEvent(name: "fadeOffTime", value: cmd.configurationValue[0])
break
case 3:
result = createEvent(name: "minLevel", value: cmd.configurationValue[0])
break
case 4:
result = createEvent(name: "maxLevel", value: cmd.configurationValue[0])
break
case 5:
result = createEvent(name: "presetLevel", value: cmd.configurationValue[0])
break
case 6:
result = createEvent(name: "levelIndicatorTimeout", value: cmd.configurationValue[0])
break
case 7:
def value = null
switch (cmd.configurationValue[0]) {
case 0: value = "never"; break
case 254: value = "when on"; break
case 255: value = "when off"; break
result = createEvent(name: "indicatorStatus", value: value)
break
case 8:
def value = null
case 0: value = "incandescent"; break
case 1: value = "led"; break
case 2: value = "cfl"; break
result = createEvent(name: "loadType", value: value)
break
result
private zwaveEvent(hubitat.zwave.commands.manufacturerspecificv2.ManufacturerSpecificReport cmd) {
log.debug "manufacturerId: $cmd.manufacturerId"
log.debug "manufacturerName: $cmd.manufacturerName"
log.debug "productId: $cmd.productId"
log.debug "productTypeId: $cmd.productTypeId"
def msr = String.format("%04X-%04X-%04X", cmd.manufacturerId, cmd.productTypeId, cmd.productId)
updateDataValue("MSR", msr)
updateDataValue("manufacturer", cmd.manufacturerName)
createEvent([descriptionText: "$device.displayName MSR: $msr", isStateChange: false])
private zwaveEvent(hubitat.zwave.commands.hailv1.Hail cmd) {
createEvent(name: "hail", value: "hail", descriptionText: "Switch button was pressed", displayed: false)
private zwaveEvent(hubitat.zwave.Command cmd) {
log.warn "Unhandled zwave command $cmd"
private dimmerEvent(short level) {
def result = null
if (level == 0) {
result = [createEvent(name: "level", value: 0, unit: "%"), switchEvent(false)]
} else if (level >= 1 && level <= 100) {
result = createEvent(name: "level", value: toDisplayLevel(level), unit: "%")
if (device.currentValue("switch") != "on") {
// Don't blindly trust level. Explicitly request on/off status.
result = [result, response(zwave.switchBinaryV1.switchBinaryGet().format())]
} else {
log.debug "Bad dimming level $level"
result
private switchEvent(boolean on) {
createEvent(name: "switch", value: on ? "on" : "off")
private getStatusCommands() {
// Even though SwitchBinary is not advertised by this device, it seems to be the only way to assess its true
// on/off status.
zwave.switchBinaryV1.switchBinaryGet().format(),
private short toDisplayLevel(short level) {
level = Math.max(0, Math.min(100, level))
(level == (short) 99) ? 100 : level
private short toZwaveLevel(short level) {
Math.max(0, Math.min(99, level))
private int durationToSeconds(short duration) {
if (duration >= 0 && duration <= 127) {
duration
} else if (duration >= 128 && duration <= 254) {
(duration - 127) * 60
} else if (duration == 255) {
2 // factory default
} else {
log.error "Bad duration $duration"
0
private short secondsToDuration(int seconds) {
if (seconds >= 0 && seconds <= 127) {
seconds
} else if (seconds >= 128 && seconds <= 127 * 60) {
127 + Math.round(seconds / 60)
} else {
log.error "Bad seconds $seconds"
255
private configurationCommand(param, value) {
param = param as short
value = value as short
delayBetween([
zwave.configurationV1.configurationSet(parameterNumber: param, configurationValue: [value]).format(),
zwave.configurationV1.configurationGet(parameterNumber: param).format()
], commandDelayMs)
private setFadeOnTime(short time) {
sendEvent(name: "fadeOnTime", value: time)
configurationCommand(1, time)
private setFadeOffTime(short time) {
sendEvent(name: "fadeOffTime", value: time)
configurationCommand(2, time)
private setMinLevel(short level) {
sendEvent(name: "minLevel", value: level)
configurationCommand(3, level)
private setMaxLevel(short level) {
sendEvent(name: "maxLevel", value: level)
configurationCommand(4, level)
private setPresetLevel(short level) {
sendEvent(name: "presetLevel", value: level)
configurationCommand(5, level)
private setLevelIndicatorTimeout(short timeout) {
sendEvent(name: "levelIndicatorTimeout", value: timeout)
configurationCommand(6, timeout)
private setLoadType(String loadType) {
switch (loadType) {
case "Incandescent (default)":
sendEvent(name: "loadType", value: "incandescent")
return configurationCommand(8, 0)
case "LED":
sendEvent(name: "loadType", value: "led")
return configurationCommand(8, 1)
case "CFL":
sendEvent(name: "loadType", value: "cfl")
return configurationCommand(8, 2)
private setIndicatorStatus(String status) {
switch (indicatorStatus) {
case "When switch is off (default)": return indicatorWhenOff()
case "When switch is on": return indicatorWhenOn()
case "Never": return indicatorNever()
You could make one change to that driver to fix this problem:
In the method "dimmerEvent", where it has this line:
change that to this:
result = createEvent(name: "level", value: toDisplayLevel(level), unit: "%", type: "physical")
See if that fixes it...
There's a chance that that might mess it up also, and also set override on. "physical" is tricky.
Did not seem to make a difference but I will test some more have to go out for a bit.
What we want to see are the device events, after you make that the active driver for Office Lights with that change.
If that doesn't work, I may have to change how Motion Lighting works to accommodate devices like this.
So that looks like it worked. I tried changing the level after the light was turned on from a motion event and the new dim level stuck and was not changed by motion. I also turned the light on manually and the motion events did not turn off the light or change the dim level.
I did have to delete the device and re-add it. For some reason when I switched drivers from the modified one i use to the stock Generic Z-Wave Dimmer it messes up the dimmers where they do no report the on/off state properly.
On a side note I also found that when HE discovers these Leviton Dimmers, they are only see as "Device" and not a "Generic Z-Wave Dimmer."So it seems HE does not fully detect this particular model, not sure if that is something that can be fix.
Below is the current event log. The 30% level is the motion event the others are me manually changing the level.
Thanks for the help.
So I did a little more testing this morning and the lighting app was not obeying the override, it would still change the level after I manually adjusted it when motion was detected. Not sure why it worked yesterday.
If there are any other changes to try I can test them. Thanks.
You need to track through the various trouble shooting steps from earlier. Look at the app status page after you adjust the dimmer, see if the state variable "override" is being set to true or not. Check the device events list to see that it is reporting type "physical", etc.
So what I am finding is the Motion Lighting App is acting erratically. First it was not obeying the override so I deleted the smartapp and re-configured everything. At this point the override was actually working. Then a couple hours later motion events are not triggering the light to go on anymore. I can control the light manually through HE fine.
So then I checked the app's application state and the "override" option was stuck on "true." Turning the light on/off or any motion did not change this. I even removed the override setting from the app and it was still stuck on true.
In the device's event log when I manually turn the light on it is recognizing the switch input as a "physical" type. Although I noticed that when I turn off the light manually there was no "physical" type displayed.
The only time the app cares about physical wrt override is turning it on. Override is cancelled by any off event for the device. That's how the software works.
So, not sure what's going on with your situation, although the first thing to trouble shoot are the device events relative to the override setting. You could keep the Device Events page open in one tab, and the Apps status page in another. Both of those pages would need to be refreshed to see latest values. Turning the switch on, or setting its level, should turn override to true, and turning it off should turn it to false.
Check that, and see what specifically is going on. Let me know what you see.
In that screenshot it showed a scheduled job for turnOff pending. So it seems as though it was set to turn off those lights. Isn't that the desired result?
The problem is even after the light has been turned off manually the "override" option is still true. It's not resetting back to false, so therefore the motion lighting does not function the next time motion is detected.
OK. We are looking at that driver of yours again. This is most likely some issue with it.
Yeah, I also feel like HE was never really detecting these Leviton dimmers properly because when I pair them with HE it always detects them as "device" for the driver and not Generic Z-Wave Dimmer. That was the main reason why I always used the custom driver, plus it also offered some nice functionality.
