Here is my rule:
This rule seems to work well, although I have a query as to why my lights did not turn off this morning.
The lights were turned on via this rule at before 8am through motion and low light outside.
At 8:22 AM the rule went false (due illuminance >1000). Delay off by 10 mins, so was scheduled to turn off at 8:32:23 AM.
However, at 8:32:16 AM, this rule was paused by another rule (my garage door opened when I went out to play squash, and this rule was paused, to turn my lights RED to indicate garage door open).
When the garage door shut, this rule RESUMED at 8:33:57, which is after the scheduled turn off. The lights did not turn OFF.
I presume the lights failed to turn off because at the scheduled time of 8:22:23 + 10 mins the rule was paused. Is that a correct assumption?
And if that is the case, does pause and resume not work with delayed off? My question is what does pausing a rule actually achieve when it comes to delayed off?
