Rule for TTS
Hi there, I am stuck with a rule again :slight_smile:
I have a button at my main door, which when pushed, turns off all of my lights and media. Now what I would like to accomplish is for another rule to check again if everything is really turned off: For this rule I used the button as a trigger and a wait for condition with a timeout of 5 seconds. If the condition turns true within those 5 seconds (or already is true) TTS should say "Everything is off". Now this works so far! However here comes the hard part: if the condition for some reason doesn't turn true I would like TTS to tell me which device is still on.
This seems pretty complex to me. But is this possible? I'm curious what solutions you guys come up with! :smiley:
Best regards!
"Check Open Contacts" app from @Cobra may help you here.
This is how I use my "goodnight" routine.
Its available at https://cobra-apps.co.uk if your not a member, sign up is free and I can approve you straight away :+1:
Thanks for your answer. I would prefer to stick to the in-built rule machine. But what is cobra apps in general? Could you explain? Thanks
@Cobra is a HE community developer, and a good friend :slight_smile: .
We have collated all his apps and drivers and created the website, so people can join, and obtain his apps etc. Its just more secure than using Github thats all.
Ok thanks! If no solution can't be found with rule machine I will contact you again and ask for access to this website!
Thank you!
Simply register, and you'll find a host of useful apps and drivers there :+1:
Cobra apps is the simplest method, to do what you want in RM you have to write a rule that checks each sensor separately then appends to a variable the sensor open. It becomes very long and tedious.
I used to have the rule and posted it somewhere.(notice the used to...)
Ok thanks. I just registered and will try it out. @Royski Could you approve me? Best regards
Already done yesterday :+1:
Ok so I got the app. Thanks a lot! However how can this be the right app for my purpose if it only checks for contact sensors to be open or closed? I would need it to check all of my switches instead....
It can turn off all your switches. Just use a contact you know will be always closed.
Then it’ll turn off all you need, and you can add the msg to TTS.
Sorry I don't get it. Rule machine can also turn off all of my switches. I was looking for a way to have rulemachine/a different app check the states of my switches and then tell me what is still switched on. (See my inital post)
Also as far as I can see the app does only turn switches on and never off?!
