I have a rule setup as follows:
When Time is 7:00AM
Fade Light to 100 in 5 Minutes...
The rule is firing at 6:00AM, I verified my hub has the correct time what would cause this to fire a whole hour early?
When Time is 7:00AM
What do logs show? Mind sharing a screenshot? That might help identify the problem.
https://docs.hubitat.com/index.php?title=How_to_Troubleshoot_Apps_or_Devices#App_Troubleshooting
2022-08-18 07:04:43.645 am info G Light was turned off [physical]
2022-08-18 07:04:42.750 am info G Light button 2 was pushed
2022-08-18 06:05:01.174 am info G Light was set to 99% [digital]
2022-08-18 06:03:01.070 am info G Light was set to 60% [digital]
2022-08-18 06:01:00.275 am info G Light was set to 20% [digital]
2022-08-18 06:01:00.272 am info G Light was turned on [digital]
EDIT: I didn't have logging turned on for the rule, I changed the time in the rule to 08:00 and enabled logging, more tomorrow.
Do you mind going into Apps, then click on the gear icon next to your rule and post a screenshot of it's settings and schedules?
It's pretty clear that it came from a rule, if it was a one off event, it might have been different, but fading commands over 5 minutes is pretty telling.
