Rtsp feed
I have 4 android tabs and 2 fire tabs running hd+' over last few weeks the android tabs are giving me " broken pipe" errors after a few hours streaming rtsp feed? The fire tabs are fine ? When you restart the feed it works straight away but fails again after few hours .
A
Can any one help
You'll probably get more help if you post this in the HD+ thread. :thinking:
More support info here:
If you're able to run the newer version I've been spending a lot of time getting it to the point where it's likely even more reliable for playing RTSP video.
For either version, if you enable debug mode, reproduce the issue and then send device logs (menu -> about -> support) I can likely fix it
Have you checked to see if your Hub is restarting after a period of time. What is the resolution of your video streams?
