Routines messed up + Google home issues
For the past few releases not sure when but none of routines are working. Lights randomly turning on, upon checking i saw google triggering the alerts for lights so I removed it completely
Now I can't add google home devices it says can't add or at times gateway 504 error
Any one who can help?
Which routines, on the hub, or on Google Home?
Not sure what you mean by this ... What alerts, where?
Are you using Hubitat's built-in Google integration, or the community version?
Have you rebooted your router recently, that could result in your hub getting a different IP address if you don't have DHCP reservation for it in your router (preferred), or haven't set a fixed IP on the hub, which could cause problems.
Hubitat hub routines , icons also show false status , garage door, lights showing as if they are in but in reality they aren't
Error says oauth. In google home add a device then works with google then find hubitat and re-enter your hubitat credentials. My integration got mad at me once and that's how I fixed it. Hope that works.
