As I dive into this, I'm wondering which is the better way to do a few things.
Room with two lamps on plugin dimmers and one 5-button Lutron Pico.
I currently have used Button Controller to set actions on several of the buttons on the Pico to be able to control both lights from the Pico. For example: Button 1 will turn on Light A when pressed or Light B when double tapped. Button 3 will turn both on to Full when pressed and both to Half when double tapped. Button 5 turns All Off when pressed.
Or, should I be doing this in Room Lights, creating different "scenes" and assigning their actions via buttons there?
