Hi folks, I bet it was explained already, but I couldn't find the exact discussion; please point me to it if it exists.
I have two use cases for light automation:
- Mode change (turn off when night and away)
- Motion sensors turn lights in bathrooms, closets, doorways, etc. on when motion and off when motion stops.
I used to do the first one in RM (in mode change trigger), but since I am ending up with a lot of lights, some of them are randomly skipped (not sure why, but that's a different debug discussion), so I decided to give RLA a chance to turn lights off per room when mode changes.
My question is about the second use case. For now, I have a bunch of SARs "turn on on movement, turn off when stopped". I can instead theoretically create a room for each closet/doorway/etc. and automate the act/off there with the motion sensor as the trigger.
It looks like an overkill (a room for each closet?), but maybe it's the right way to go. What do you think?
P.S. Some devices in the room have separate rules (e.g. a fan in a bathroom should be turned on by humidity and/or turned off by a timer, while the lights are triggered by motion), so what do I do? A separate room for the fan?
