Room Lights app problem
I want to control some laps according to the time table
I install mode manager and configure periods, it works ok, modes are changing.
I'v installed Room Lights
select device to automate
and via Set Up Lighting Periods or Re-Capture Devices
set Vary Lighting Using set via Hub modes
when in app i test buttons Activate and turn off they work ok
but automatically the lamps don't start, what I'm doing wrong?
Question
do we need to configure anything for
Means to Activate Lights
Means to Turn Off Lights
or we can leave them without any configuration
Are you trying to set a round the clock schedule for the device and you always want RL in control of it? (Tip RL "activation" does not mean the light will always be ON, just that RL would be in control of the light).
First you need a way to activate the light, f you are going for 24/7 activation you could just set the means to activate as a time of the day, like 8am, which would make sure it stays activated.
Second there is a setting within the means to activate to turn on that will force the light to change as the modes change.
Hello
Thanks for replay. In my case the problem was that I set Means to Activate Lights and Means to Turn Off Lights but I didn't set Set Up Lighting Periods, when I did it everything starts to work fine :slight_smile:
Thanks for help
