Room Lighting - Use Stay Minutes Per Mode reduces grainular control. Intended?
Room Lighting -> Set up automation -> Click ' Set Up Lighting Periods or Re-Capture Devices' -> There is a toggle named: 'Use Stay Minutes Per Mode for motion and contact stays'
If ENABLED:
I can enter ONE value for "Stays Put Time" and it seems like this applies to all devices that are monitored. Motion, contact, etc.
If DISABLED:
On the "Means to Turn Off Lights" screen I can now enter MULTIPLE values for different devices in the field for "Stays off for this many minutes" field.
Is this intended behavior? I would like to be able to assign multiple values for different monitored devices with the per mode setting enabled.
