Hi,
Devices:
- RGB light switch: Living Light
- Motion Sensor: Living Hue motion sensor
- Button: Living Remote
My requirements are:
- Turn on when:
- movement is detected (including zone motion trigger movement) AND illuminance is less than a certain level
- OR when button is pressed
- Turn off when:
- movement is no longer detected
- OR when the illuminance is rising above a certain level
Is this the correct Room lighting conditions?
As I found it wasn't working well, there are times the light does not switch itself off - unless I'm dreaming...
Thank you
