Room Lighting Transition questions
I think I verified this issue was fixed a few releases ago, but I'm running into the same thing again on 2.3.4.148. Triggering "Turn Off" doesn't seem to be cancelling the turn-on transition.
A couple other things about transitions:
  • It appears that the target bulb's level and saturation get transitioned, but the hue only gets set at the very end in the final state. Is that expected?
  • When I make an RL instance a Transition, like this:
    ...my expectation was that it would transition from the first table to the second; that is, set the first table, then start the transition. However, it actually seems to transition from the current state to the second, ignoring the first table. I can work with either one, but I'm confused what the first table is for, in that case.
Please show the main RL page.
(On this test, I'm just using the on-page Activate and Turn Off buttons so far.)
@bravenel, I'm just checking to see if that screenshot had what you wanted to see.
@bravenel, found another transition-related issue (surprise?) in 2.3.5.108.
When I configure an activation transition, like so:
Devices in the list that are Dimmers or CT which are selected not to activate do still turn on when the transition fires:
(If I change the type to Switch, they properly don't get activated, so there's a workaround.)
Download the Hubitat app
