Room Lighting: Toggle on button push vs activate/deactivate
Each new Room Lighting rule defaults to include a "Means to activate" and a separate "Means to deactivate".
For a simple button/light set-up are there any benefits/drawbacks with the default set up compared to just having a "Means to activate" toggling the lights on and off with a button push?
They are generally for two slightly different scenarios. Toggle is for using the same button; whereas, using the Means to Activate/Deactivate are generally for two different buttons.
Cool - in my case I'm always using a single button, so I guess it doesn't matter which approach I use.
Thanks!
