Room lighting fails to deactivate after hub update
Model C8, Platform version 2.3.9.154
For some reason, my room lighting for my garage fails to turn off the lights. It does turn off when I click the button 2 per my setup in below image. But when the motion sensor goes inactive and after 10 mins, nothing happens when it should have turned off the lights.
I see you have logging enabled. The best clues are are going to be there. What do Past Logs, filtered to just this app (use the logs icon on the upper right of the page you took a screenshot of to get there easily) say?
Logs just show it being activated. The motion sensor logs show active and inactive. Seems like the room lighting is not getting the motion sensor deactivation. This series of updates seemed to have cobbled it?
Have you tried hitting "Done" in the RL instance to re-initialize device event subscriptions? (Or maybe you never did if you added this sensor after creating the automation in the first place?)
