Is there an option in Room Lighting to specify a fade time (to go up from off; to brighten gradually)?
If not, what app would you recommend for this?
Device Transition Time should do it, if your driver and device support it.
How about the other way? Is there a setting to fade down from current level to off? I can’t find it anywhere…
Did you figure this out? I want to be able to fade my lights down over the last 1 minute before it shuts off the room light.
Explained in the other thread you posted on:
