@bravenel
In Room Lighting under "Disable Activation upon these Events" option, can you add the option: "Variable becomes false"?
There's already "Variable becomes true" but no "Variable becomes false" option. This is under the "Means to Activate Lights" section. This would mean the "Re-enable Activation upon these Events" option would need updated to "Variable becomes true" as well.
It'll flipflop this part:
It looks like the "Means to Turn Off Lights" section already has both options under "Turn Off Lights Options"
