Something is wrong with room lighting in the latest update (I’m on 2.3.8.134) whereby the active status is not showing correct when the app is set to show active for scene set. You can see in my images and the logs, I have it set accordingly, but it’s logging “already” off when illuminance changes, when in fact the lights are “on” per the table. I changed it to “indicator if any are on,” and then the active status shows correctly. Also happening to my other room lighting apps that are set this way.
Are they Hue bulbs?
No, outlets. But I tested on another app that uses Hue bulbs. Why do you ask?
Only to see see if "power-on" settings came into play, like they may have for me today when arriving home.
