My 5 minutes of searching didn't help, so sorry if this has been covered before.
Is there a way in a RM 4.0 to tell which trigger kicked off the rule?
I have a situation where a button press, or a switch, can fire off a rule. They trigger as expected, but I can't check the button press in a condition, as it is a finite event and no longer true by the time you check the condition...
There are a bunch of ways to work around this, so it isn't the end of the world. But it would be a simple rule if I could just tell which trigger started it to begin with, and use that in an IF statement.
