Hello, I am looking for help please. Here is the set up. I do not use a lot of motion sensors today, as such I have timers on lots of lighting devices to turn them off after a period of time.
In RM.25 I needed a rule for each device. I am happen to be at a place where I have had to move everything from that hub and toss it in the bin and I am therefore re-writing every rule under a new device. So I am looking to see if I can optimize the rules. Does anybody know if I can write 1 rule that independently tracks each light to see if it has been on for 30 minutes and then turns it off?
Trigger: For each light, turns on
Action wait 30 minutes (whatever) and turns that light off - but not all the others - hence independently.
As a developer myself I've asked myself more than a few times since i've been into Hubitat "why isn't there a 'this' reference inside the rule machine?"
As you noted in your first post, not having that reference sure adds a lot of unnecessary time/setup
I use that extensively. It isn't as good as a real "this." As it still requires more work in the condition, but I can usually get to the same end result - which is the main thing.
would this work to control differnt switchs indpendently, ie use the same rule for diffent switchs by adding them as a trigger? the format isnt right, but the concept?
triger events
light 1 change, light 2 change
actions
if %device% on then
%device% off delayed 0:20:100 (cancelble)
else
%device% cancil deley
end if
I too would love to see what the rule for this actually looks like
The example in a few posts above doesn’t make much sense since I can’t see the whole thing and am not understanding what it actually does or how multiple devices are involved as trigger. At least it made me think “at least it’s possible” though!
