When editing a rule today, I managed to run into this error twice, and can then no longer edit the rule(s) and have to recreate it from scratch.
So I think I know roughly how reproduce it...but it takes a bit of poking around. Each time I was looking for a particular action and where it would be hidden, so it involved going through nearly all possible actions.
Problem:
RM4 new rule, set a trigger on Switch Change. (don't think it maters)
Edit the action of the rule.
Insert a new action.
Poke around through the possible action types. Select an action category, and perhaps even select an action. Then go back and change the category. After doing this for 3-4 mins going through various options I get a dialog saying there's been a the above failure.
From then on you can no longer edit the rule and must delete the rule and re-add it from scratch.
In the logs this is logged:
[app:483](http://hubitat.local/logs/past#app483)2019-09-07 05:49:47.063 pm [error](http://hubitat.local/installedapp/configure/483)java.lang.NullPointerException: Cannot invoke method tokenize() on null object on line 2214 (selectActions)
Misc info: FW installed is current. Web browser is mobile safari.
You have an If statement followed by an END-IF. Why? If you're not going to do anything, why bother checking the condition? I think that might be your problem. It's a malformed rule.
Because when adding the body the RM decided to corrupt the rule. When I rebuilt the rule it was linearly, and it corrupted the rule exactly the same way when inserting a new action and going through and changing action categories.
So 2 points:
Same error occurred regardless of the empty if
An empty body on an if while unusual isn't a reason to corrupt a rule, and if were an issue would also be a bug. (Many worse things happen when editing rules)
It corrupts in step 4 of my instructions. But it's not: click rule category "Conditionals Actions", then change to "Delay or Repeat action Wait" and crash. Rather it's switch around for a while and then bam
I have a video screen capture reproducing the bug. It's 2 mins 15s long showing me reproducing the bug. I can't attach a video to the forum, how would you like me to get it to you?
I'm having this same error with the button controller after I deleted a device and it broke the rules for the buttons and need to fix them.
I had to delete the button controller and recreate the rules.
Same error happened to me the first two rules I have ever created so not a great start with rule machine, yes I likely created a bad condition but I am learning. I am disappointed I have to delete the entire action and start over because of this error. I will surly not be moving my more complicated processes over from webcore until rule machine is usable and more forgiving when bad conditions are created.
