I'm setting up a rule if either one of my deadbolts change state and we are not present, send a message to pushover.
If I select pushover as either a notification device or text to speech or a chromecast device as text to speech, I get an unexpected error. Any ideas?
![image](https://community.hubitat.com/uploads/default/original/3X/8/0/8007b86b6293f33e1695aa461a9184f6c7f49312.png)
Update
I found that if I turn off display current values, the error goes away. I can then setup notification and save the rule
![image](https://community.hubitat.com/uploads/default/original/3X/f/7/f70f716c2ea4e32907d1d44ed75af97ede2615fe.png)
Were you putting the Send Message action at the end of that set of actions?
What exactly was in the Send Message? Was there by chance something like %variable-name%?
Here is the working RM:
Can you not use variables when display current values is turned on?
Yes, you can. I just need some help to discover what is causing the error you reported.
What does %status% refer to? The error you reported most likely stems from using an undefined variable -- and that's been fixed for the next release. Is %status% a variable?
Bruce- Many thanks for responding..
I was looking for the status of the lock when it changed. Looking at it more, I don't think that will work in this setup?
There is no predefined thing %status%. You could come up with the condition of the lock, possibly with Custom Attribute or a conditional action. So, if %status% is not a variable you have defined, then that is what caused the error. Next release will not throw an error, but %status% would not display anything as a value, since it doesn't have one.
Always learning. Many thanks for your patience and assistance. Especially on a Sunday!!
