I have a tile on my dasboard for a Rule Machine Global Variable connector. The ile gets set up with the option if it is touched to allow t set the variable toa new value. In my case I do not want the value to be editable in the dashboard tile. Does anybody know if/how this can be turned off so the tile can only display value.
Use an Attribute Tile instead of a Variable Tile.
When I set it to Attribute the only Attribute choices are HSM, Mode, or Last Updated
You should be able to pick "variable":
If you don't, then make sure that you've set the variable to an actual value (via either RM or the connector), as I do not believe the Dashboard app will show attributes that are currently set to null values. If that still doesn't work, what type of variable did you create, what type of connector is it using, and what is it currently set to? There may be a problem, and that could help reproduce it.
