Hi all, i have a rule with 2 triggers: temperature change on a thermostat, and every 30 minutes. I removed the every 30 mn trigger, but despite this the rule continues to be triggered every 30mn. Can’t seem to stop this behavior, even rebooted the hub. Any ideas?
Hi thanks for your answer. Actually i solved the issue by going into the rule and pressing "update rule" button. I had removed the trigger and pressed done, but it didn't take the trigger change.
In the manual it says " If you change the Trigger Events in any way, you must either hit Done or Update Rule button". But the change seems to have been applied only after going back in the rule and pressing update rule.
