Any idea while this Rule is repeating even though the sensor is closed?
My guess is because the only trigger is opening the fridge, not closing it? Just a guess as I am no RM expert.
Why not just use a normal "Rule" instead of a "Triggered Rule"?
I believe @ogiewon is correct. You could add an " OR Fridge sensor closed" to the trigger but the better option would be to use a standard rule with a Cancel on truth change for the action.
I think there are 2 issues here. the first one is you need cancel on truth change otherwise you will get notification after 5 minutes even when the door is closed again. The second issue is you will need to set a private boolean to false after 5 mins otherwise rm is going to check the conditions every 5 mins and give you a notification.
you can do this with HSM which I find is easier.
Changed it to a regular rule and it's working.
