After starting a conditional statement, you are presented with buttons to add either ELSE or END-IF. It would be great if another can be added for ELSE-IF. I end up using END-IF as often as ELSE or END.
No, this can't be done with a button in the current UI. ELSE-IF is almost identical to IF-THEN, and requires creating a new expression. Whereas ELSE and END-IF are just effectively tokens with no other inputs associated with them.
Shot down again.
