@bravenel I'm using RM 5.1 [2.3.3.140] to resume a Simple Automation Rules and I'm getting a reproducible error:
Not able to reproduce this on 2.3.4.114. You should update your hub to see if that fixes it.
@bravenel Updated to beta and still getting the error. I even recreated and still got
Show the SAR rule setup page. Also, confirm that this is SAR 1.2 rule?
2.3.4.114 is not beta. Is this what you updated to?
Very strange. That error makes no sense. What is app 1156?
That's my SAR, it's listed as Simple Automation Rule (and not 1.1 or 1.2)
I'll make a new 1.2 and see if that works.
SAR 1.2 is working without errors. Looks like I need to update some rules here.
And, RM needs to check and not offer old SAR in that action. I saw in the code that it doesn't check.
Actually, it might be easier to add pause/resume to that old version of SAR.
This will be fixed in the next release.
Thanks, Bruce!
Fix is as I said, to the old SAR. Hasn't been touched in 2-1/2 years. So you don't need to redo those rules unless you can't wait until Monday.
I only had a couple so I already updated them. I can restore a backup if you want me to verify that it works on this end.
No need. I know for sure it works.
