RM 5.1 "*is empty*" UI bug
@bravenel New RM bug, just spotted:
  1. Create new Rule
  2. Create Local Variable of type "String" (any name, any value)
  3. "Select Actions to Run"
  4. "Create Conditions"
  5. Select capability for new Condition "Variable"
  6. Select local variable
  7. Select Comparison "is empty"
RM UI is now unresponsive. Exiting (via "Apps", for example) and re-entering rule may allow you to edit/remove condition, or may leave you with no choice to delete rule.
Yes, this is a bad break. It goes into a refresh infinite loop. Will track it down.
Fix for this in next release.
