Hubitat 2.3.0.124
This is a problem in RM 5.1 copy/pasting a Simple IF condition executing a Wait Event:
If the If/Wait Event is pasted immediately afterward this error is displayed:
At this point the only way out is to remove the app. This happens consistently with both regular and test apps.
Error log shows:
I will look into this. My guess is that it has to do with the Simple Conditional action. If you use IF-THEN it will probably work.
Will report back on what I find.
A variation of this was reported before, and it turned out that the problem is the Wait with a Simple Conditional action. This will be fixed in the next release. As above, use IF-THEN instead...
