Logging for Events, Triggers and Actions is on for the RM 5.0 rule, but nothing shows in the Event tab. Is there a different setting that I missed turning on?
Logs page, not Events for the app.
Do you have the logging turned on the for rule? Events, Triggers, Actions?
Also, please post a screenshot of the Event Subscriptions portion of the rule's App Status page (gear icon).
Logging is turned on:
Event Subscriptions:
Thank you for the assist! Learning a lot about the logging.
OK, sorry for the hassle. There was a bug found earlier today that is messing up the water sensor subscription. There will be a hot fix release coming out for it. If you can roll back to 2.2.8.152, it does not have the bug.
Hot fix release 2.2.8.156 is out, and fixes this problem.
@bravenel updated to the latest hotfix, recreated both rules, and they are working properly now!
Thanks for the assist!
-Travis
In RM 5, was the BUTTON DEVICE option been removed? I'm trying to transfer my rules and so far the only way I could find to replicate my rules was to create a rule per button press. I'm using an Inovelli Red serie switch. Thanks
That functionality was moved to Button Controller 5.0.
Excellent! Thanks
In Node-Red, the Rule Machine Connectors are seen but not the Variable connectors(Hub variable). Could the issue be on Hubitat side or it's definitly on Node-Red side? Would someone have a suggestion?
Are you selecting both the parent Connector device and its component devices (the individual connectors) in Maker API?
Well, I wish I did not ask the question now. I should've thought of that. Thanks
I don't know, as I don't use Node Red. So it's just a guess on my part. Please let me know what you discover!
You guessed right. Updated everything and worked like a charm. Thanks Bruce
and I selected the device connector
