Forget about %now%. There is a condition called Time Of Day. It tests if the current time is between two times. So for your case, you just test if the time is between 8:30 and 8:30, or 4:00 and 4:00, or 9:30 and 9:30. No need for %now% or a variable at all.
All in one rule, if that's the way you want it.
I hope you follow that if the rule is triggered at 8:30, the time of day is between 8:30 and 8:30.
OK, that makes sense and yes, that works too. That's how I did it in the first place back in post 111.
I was just trying different things I guess. I do very few time based triggers. My only reason for posting above was to see if there was an easier way to do it in 1 rule with multiple time triggers without the "time betweens", as they get a little tedious to make.
I've now done it 3 different ways that ALL WORK. So that's pretty cool. Rule 4.0 has been working out quite well for me.
You could use Days of Week Schedule instead as triggers, and simplify the test for which day it is. One Days of Week would give you Sat/Sun at 8:30 and Mon-Fri at 4:00.
Here is a dopey question. If I use the same time for "time between" (as you indicated above) it always says it is true... If I use two different minutes, it correctly shows false.
Shouldn't the other two shown below show false as well? Or should you always make sure the minutes are different?
Not a big deal, as it is just as easy to make time between 8:29 and 8:31 as it is 8:30 and 8:30... Just asking.
True. But the shutoff time is the same on all days. If it’s not 9:30 pm, the only other choices are times you want it turned on. It will only be triggered at the three times you specified in the trigger events.
Yes. Hue, Saturation and Level of a color bulb can all be set from a variable. A variable can be set from any device attribute you want, and hence so could colour be using a variable as intermediary.
