RL not setting light level
I have several lights that are turned on by RL but the levels are not getting set. Help.
Below shows the level should be 25, actual is 80.
Below shows the activation with a set level.
Below shows the set level was never received as an event. Just the on command.
I tested with one of my RL apps, because I thought this may be related to the issue I am having with the indicator not showing active, but I’m not having the issue you’re having.
In your device events, it looks like the setLevel command is getting sent, so may be an issue with the device receiving the command or reporting back the updated level. Have you tried to power cycle the device? Is it Z-wave or Zigbee? Maybe do a re-pair?
