Can someone just send me the link to the app and step by step? I just want to arm my HSM and have it trigger Ring to mirror it or vice versa, I dont need to download anything else but that.
I have seen this one before, but there is no instructions after that. What do I do next? I have mastered the HE system yet. This one seems a little more detailed.
Step 6: Under the “Home” location (“Home” will be whatever you name your location), Select “Ring Virtual Alarm Hub”. It should have been discovered and selected in step 3.
Step 7: Within that device, select “Sync Ring Alarm mode to HSM mode?”. With this checked, when you arm Ring, HSM will arm and vice-versa. If you want the opposite, Ring modes to follow HSM, you will need to create a Rule in Rule Machine that does that. Personally, I prefer that when HSM is armed, Ring gets armed, but I prefer that disarming HSM does not disarm Ring.
The built-in integration with HSM is only one-way. HSM will mirror Ring, but not the other way around.
To synch Ring with HSM, a Rule is required.
Here is an example of a way to arm Ring when HSM is armed. The rule could be updated to also disarm, but personally, I wouldn’t recommend disarming Ring that way as I suspect it is easier to disarm HSM than it is to disarm Ring...
You will need to type it in. It ends-up being a parameter value to the “setMode” custom command. Makes sense?
If you go to the device, you’ll be able to see the “setMode” command and the parameters are in the drop down. In rule machine, they have to be typed instead.
Im lost on this part, I want to create 3 rules. One to Disarm the Ring, Arm the Ring when I am home and Arm Away. I just want all 3 modes to mirror so if I click arm on HSM, then Ring will be set to Away.
