@dennypage@672southmain - I'm seeing some strange behavior that I wanted to check with you. The powerSource attribute is not changing until I hit "refresh" on the device page.
Is this expected behavior? Is there a "delay"between when the power state changes and when it is sent to HE? I haven't changed any of the default settings for the device driver (see below) but let me know if something needs to be changed?
For troubleshooting Z-Wave or a device driver issue, I would look at the Hubitat only. Involving another system like Node-RED isn't going to help, and it may have a different idea of time than the Hubitat.
The communication from the Ring RE2 to the Z-Wave hub is immediate. Look on the Hubitat device Events tab and/or the log to see timestamps from the Hubitat point of view. Turn on debug logging to see more information.
One thing to note about the Hubitat device Edit page is that it can go stale. If you are looking at that page and expecting to see the powerSource immediately change under Current States, you need to make sure the web page itself is refreshed prior running the test. Don't switch to another tab or window during the test.
Note also that the Hubitat device Events page does not auto update. You need to refresh the page to see new entries.
I had both open only because I could not see the "trigger" event in HE when I unplugged the Ring Extender. The timestamps are actually identical when the event was registered (11:25:41 AM) after I hit the refresh.
That was the 2nd screenshot. The logs also show the "battery" event at 11:25:41 and then nothing when I plugged it back in.
Yeah - I'm aware of that. Refreshing the web page did not update the powerSource attribute which was why I hit the "Refresh" button.
I wonder if this is an incomplete pairing or mesh issue? I'm on a C-5 so use the "inclusion" process. Also, I have a mains powered Z-Wave switch (UltraPro) about 10ft away (HE is a bit further)
EDIT/UPDATE: The device compatibility page does not list Ring Alarm Range Extender v2 on the compatibility list (only v1 is on the list). However, all the other Ring v2 devices have a qualifier of "C-7 Required". Can someone from HE (@bobbyD@support ) confirm if this device will work with a C-5? If not, I can still return it....Thanks.
I'm having trouble excluding this from my C-5. I've tried through the "Remove Device" and through the "Z-Wave Exclusion" process. The instructions (for the v1) say to press the button on the right side of the device, but that is not working.
I have also tried the following steps from the Ring support site:
What if I need to remove my Range Extender(1st gen and 2nd gen)?
In the Ring app, tap Menu , then tap Devices , then tap Alarm Base Station , then tap the Range Extender you wish to remove.
Tap the Gear icon on the top right corner, then tap Remove .
Unplug the Range Extender and then plug it back in.
Wait a few seconds and if nothing happens then press and release the button on the right hand side.
The app will let you know the device was removed. Leave the Range Extender unplugged until ready to use again.
Any suggestions on next steps? If I do a force exclude, will that mess up my Z-Wave mesh?
Unlike C-7, the C-5 model will not let you remove a ghost device. By force removing a Z-Wave device, you leave a "ghost" device behind. The hub will eventually remove it during the nightly clean-up process. To avoid "ghosts" always exclude the device first, if possible and never force remove it, unless the device is dead or has a non-functional Z-Wave radio.
That's what I'm trying to do, but it will not exclude. The device is still connected to the C-5 and if I unplug it and hit refresh on the device page, I can see the powerSource change to "battery". Then when I plug it back in and hit refresh again, the powerSource changes to "mains".
Not sure what I can do to get it to exclude now... is force remove the only option?
I tested with a C-5. The spontaneous generated powerSource events are not transmitted. Other functions, repeater, range and power test function as intended. Sorry.
Same here. I have an intel iMac, and I use Bootcamp with Windows 10. Works fine. It’s the only thing I use Bootcamp for.
While there is an installable version of Simplicity Studio for Mac OS, The PC Controller module only runs on Windows (including on Bootcamp) and is not a part of the MacOS install.
