Ring Outdoor Motion Sensor - Hubitat Compatible?
I bought a Ring outdoor motion sensor thinking it was compatible with Hubitat but I can't get to pair. I assumed it would work since I was able to get two Ring contact sensors working. Also, the Ring indoor motion sensors are listed in the Devices section of the Hubitat portal, so I figured the outdoor sensors would be compatible as well. Can you all confirm if these are compatible or not?
Ring has 2 (at least) different protocols running. The devices running ZWave+ largely seem to be compatible with HE. Believe the device you're looking at requires the Ring Lighting Bridge which is not ZWave and is not compatible with HE.
